2.2 liter engine toyota camry 4 cylinder,1999, is it an interface engine.I ment if the timing belt brakes does the piston touch the valve and damage the motor.
what is the indication to change the timing belt.
does 1999 camry 4cylinder have an abs as my vehicle doesnot have but I see open holes under the hood near the headlight assembly pasanger side.
My braking is bad I changed the disk, pad, balanced the wheel even then I have vibration when braking on high speed.
Oct 13, 2010 at 8:58 PM
