I am having a hard time locating the charcoal canister on this car. Where can I find it and what does it look like? Is it square or round.
Jan 14, 2008 at 12:06 PM
MASTERTECHTIM
CERTIFIED EXPERT
its square and you cant miss it. look under the rear of the car at the back side of the gas tank. there is usually a exhaust shield you have to remove to replace it. let me guess you have a code for leak in evap system, this is usually the evap solenoid which is mounted to the canister. ***this can be changed seperately if its not corroded for alot less money than buying the whole canister. i hope this helps
Jan 14, 2008 at 12:10 PM
LOSTINMARS
CERTIFIED EXPERT
unless i missed something toyota doesn't sell the valve on the cannister. its serviced as an assy.
