My engine makes a loud humming sound that gets loudest between 30 and 40 mph. Above 40 mph the hum quiets down a bit. The engine does not make the sound while idle. The sound appears to be coming from the left side of the engine. This issue started a few weeks after I had my water pump and timing belt replaced. I'm not sure if the issue is related to this repair but I wanted to include it just in case. I have heard that humming can be caused by a faulty PCV valve. My PCV valve was replaced about 20K miles ago. Would it be worth replacing this?
Sep 17, 2009 at 2:02 PM
