[quote:2074cd2ab6="chuckbrazie"][quote:2074cd2ab6="stevew84"]Since it only does it cold I would wait till it cools downs to do it. you need the problem to happen and look at your fuel trims and write it down. Wait a second or two to right it so the scanner can get the right data. Brake torque for at max for 10 seconds. So I want to get this straight. This only happens when it is cold? It is ok at idle? But when you step on the gas to go(could brake torque to duplicate) then it wants to buck and chuck but then after a few seconds it goes? After it warms up it is fine? No codes?[/quote:2074cd2ab6]
It only happens when first starting after overnight, it seems to fast idle ok, but when you put it in drive, it hesitates, seems like it will stall, but then after just a few seconds, it takes off and then runs just fine. No codes/check engine light.[/quote:2074cd2ab6]
The brake torque test in the morning produced the same effect, it stumbled. If this was an old car I would believe the choke is not working or sticks when cold. :-) Here is my frame data, I did not get it to 2500 since it was stumbling:
ENG SPEED RPM 0
COOLANT ÂF 84
ST FTRM1 % 0.0
LT FTRM1 % 3.9
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame -2 Time -2.9
ENG SPEED RPM 285
COOLANT ÂF 84
ST FTRM1 % 0.0
LT FTRM1 % 6.2
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame -1 Time -1.4
ENG SPEED RPM 1563
COOLANT ÂF 84
ST FTRM1 % 0.0
LT FTRM1 % 3.9
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame 0 Time 0.0
ENG SPEED RPM 1685
COOLANT ÂF 84
ST FTRM1 % 0.0
LT FTRM1 % 3.9
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame 1 Time 1.5
ENG SPEED RPM 1529
COOLANT ÂF 84
ST FTRM1 % 0.0
LT FTRM1 % 3.9
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame 2 Time 2.9
ENG SPEED RPM 1456
COOLANT ÂF 82
ST FTRM1 % 0.0
LT FTRM1 % 3.9
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame 3 Time 4.3
ENG SPEED RPM 1446
COOLANT ÂF 82
ST FTRM1 % 0.0
LT FTRM1 % 3.9
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame 4 Time 5.7
ENG SPEED RPM 1454
COOLANT ÂF 82
ST FTRM1 % 0.0
LT FTRM1 % 3.9
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame 5 Time 7.2
ENG SPEED RPM 1466
COOLANT ÂF 82
ST FTRM1 % 0.0
LT FTRM1 % 3.9
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame 6 Time 8.6
ENG SPEED RPM 1502
COOLANT ÂF 82
ST FTRM1 % 0.0
LT FTRM1 % 3.9
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame 7 Time 10.0
ENG SPEED RPM 1383
COOLANT ÂF 82
ST FTRM1 % 0.0
LT FTRM1 % 10.9
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame 8 Time 11.4
ENG SPEED RPM 1325
COOLANT ÂF 82
ST FTRM1 % 0.0
LT FTRM1 % 9.3
FUEL SYS 1 OPEN
FUEL SYS 2 N/A
ST FTRM11 % 0.0
Frame 9 Time 12.8
ENG SPEED RPM 1227
COOLANT ÂF 82
ST FTRM1 % 0.7
LT FTRM1 % 5.4
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
ST FTRM11 % 0.8
Frame 10 Time 14.3
ENG SPEED RPM 1550
COOLANT ÂF 82
ST FTRM1 % 1.5
LT FTRM1 % 7.0
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
ST FTRM11 % 2.3
Frame 11 Time 15.7
ENG SPEED RPM 1443
COOLANT ÂF 82
ST FTRM1 % 2.3
LT FTRM1 % 5.4
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
ST FTRM11 % 3.9
Frame 12 Time 17.1
ENG SPEED RPM 1660
COOLANT ÂF 84
ST FTRM1 % 4.6
LT FTRM1 % 3.9
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
ST FTRM11 % 7.0
Frame 13 Time 18.5
ENG SPEED RPM 1787
COOLANT ÂF 84
ST FTRM1 % 9.3
LT FTRM1 % 3.9
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
ST FTRM11 % 11.7
Frame 14 Time 19.9
ENG SPEED RPM 1830
COOLANT ÂF 84
ST FTRM1 % 13.2
LT FTRM1 % 3.9
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
ST FTRM11 % 17.1
Frame 15 Time 21.4
ENG SPEED RPM 1864
COOLANT ÂF 84
ST FTRM1 % 18.7
LT FTRM1 % 3.9
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
ST FTRM11 % 20.3
Frame 16 Time 22.8
ENG SPEED RPM 1891
COOLANT ÂF 86
ST FTRM1 % 21.0
LT FTRM1 % 3.9
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
ST FTRM11 % 21.8
Frame 17 Time 24.2
ENG SPEED RPM 1714
COOLANT ÂF 86
ST FTRM1 % 11.7
LT FTRM1 % 3.9
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
ST FTRM11 % 17.9
Frame 18 Time 25.6
ENG SPEED RPM 1836
COOLANT ÂF 86
ST FTRM1 % 2.3
LT FTRM1 % 10.1
FUEL SYS 1 OPEN1
FUEL SYS 2 N/A
ST FTRM11 % -6.3
Frame 19 Time 27.0
ENG SPEED RPM 1775
COOLANT ÂF 87
ST FTRM1 % -22.9
LT FTRM1 % 7.8
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
ST FTRM11 % -21.5
Frame 20 Time 28.5
Jul 17, 2009 at 7:44 AM
