Brakes problem
1999 Toyota Camry 4 cyl Two Wheel Drive Automatic
Brake problem. We had the front brake pads replaced on our 99 Toyota Camry and about a week after that the front driver wheel would start shaking when driving on the highway and a strong burn smell was noticed.
After getting the car home I noticed smoke coming from inside the front driver tire rim and strong metallic burn smell. Also noticed without applying the brakes the car would slow down as if the brakes were being applied. Even got to the point I had to give it a little gas to keep going. It was like applying the gas and brake pedal at the same time (did this because I was literally 1/2 block from my house). I was told the caliper was bad so I replaced it, but the symptoms are still the same.
Any suggestions as to what's causing the problem.
Jul 19, 2010 at 3:33 PM
