1998 Toyota Camry Transmission service confusion
1998 TOYOTA CAMRY
CAMRYNCA
  • 5 POSTS
Transmission problem
1998 Toyota Camry 4 cyl Automatic 167107 miles
I have a 1998 Toyota Camry, 4-cyl with about 167K miles. I have never had the transmission serviced. It seems to be running fine. I wanted to take it in for a flush. In the process of calling around for pricing, I have received a couple of varying opinions on what would be the BEST course of action. Several places said they would not do a flush because it could lead to bigger problems by dislodging sludge, etc and ultimately hurt the tranny. It was recommended that I do drain and fills to replace the fluid. I definitely don't want to cause a more serious problem, espicially since there is no appearent problem currently other than dirty fluid. Is it better to do a flush or a drain? Also, is there a difference between a "power flush" and just a "flush"? I am more confused now than when I was prior to realizing I should service the tranny in the first place.
Thanks for any and all advice.
May 5, 2009 at 7:43 PM
2CARPRO JACK
  • 11,533 POSTS
I too would probably only do a drain and fill type of service, with a new filter.Flushing as you said breaks up material and can cause leaks and even failure. They arent a bad idea in general, but with the mileage you have I wouldnt do it.
May 5, 2009 at 9:43 PM
CAMRYNCA
  • 5 POSTS
Thank you for your reply! Will a drain and fill clean the lines and converter as well?
May 5, 2009 at 10:47 PM
2CARPRO JACK
  • 11,533 POSTS
No, that is what a flush does,Try removing the pan and changing the filter and refilling it.Drive it a few miles, then if equipped, remove the drain plug in the pan and drain and refill.I think that would be your best bet, to slowly mix in fresh fluid rather than flush it all through at once.
May 6, 2009 at 7:49 AM
