tail light fuse keep blowing off
1998 TOYOTA CAMRY
110,000 MILES • 4 CYL • FWD • AUTOMATIC
HIDME
  • 27 POSTS
My tail light fuse kept blowing out. I first noticed the tail light off, and replaced fuse and it was ok. but it blew out in a few days. So I changed another fuse, lasted a few weeks. I so far changed almost ten fuses, some last a few days, some last a month. Can any one give some clue what might be the cause of the fuse blowing out.
Thanks
Mar 25, 2009 at 9:31 AM
KHLOW2008
  • 41,814 POSTS
Hi hidme,
Since problem happens intermittently, it most probably is due to a bare wire that shorts to ground due to bumps etc. Check for exposed wires that might be shorting intermittently.
When fuse does not blow, check brightness level of all illumination lights and if any seems different, check the bulbs.
Is there any light failure indication when fuse is working correctly?
Mar 26, 2009 at 9:47 AM
HIDME
  • 27 POSTS
[quote:4aa409f0d1="KHLow2008"]
Is there any light failure indication when fuse is working correctly?[/quote:4aa409f0d1]
No, there is not failure indication when fuse is working correctly or even it not working.
Mar 26, 2009 at 11:17 AM
HIDME
  • 27 POSTS
I found broken wire close to hinge of trunk lid.
thanks
Mar 27, 2009 at 9:04 AM
