1998 Toyota Camry rear brake replace
1998 TOYOTA CAMRY
HAROLD 123
Brakes problem
1998 Toyota Camry 6 cyl Front Wheel Drive Automatic
how do you get the rear caliper off. it has a bolt on the bottom and a little rubber plug on top and metal cap?
Jul 27, 2010 at 12:45 PM
DOCFIXIT
  • 18,828 POSTS
Remove flex brake line bracket then the calpier bolt. Rotate up to clear rotor then pull off top slide pin.
Jul 27, 2010 at 1:21 PM
