1998 Toyota Camry Rattle in rear end
1998 TOYOTA CAMRY
111,000 MILES • 4 CYL • FWD • AUTOMATIC
FMIKE
Hi
this toyota has a rattle in the rear end. Sounds liike something banging under the trunk when I hit a bump. I looked under the car and every thing seems ok.
Thank you
mike
Nov 15, 2008 at 9:27 AM
JAMES W.
  • 2,394 POSTS
Mike, Check for a loose, or worn, rear strut mount. Most common cause is a broken exhaust hanger allowing the pipe or muffler to hit the body or suspension.
Nov 15, 2008 at 1:20 PM
TOYOTECH
  • 33 POSTS
The rear sway bar bushings wear and can't tightly hold the sway bar causing a rattling sound over bumps.
Nov 23, 2008 at 12:15 AM
JAMES W.
  • 2,394 POSTS
I love it when a good plan comes together.
Nov 23, 2008 at 12:06 PM
