1998 Toyota Camry Oil Leak
1998 TOYOTA CAMRY
185,000 MILES • 4 CYL • 2WD • AUTOMATIC
OWEN0118
We have an oil leak at a "fitting" on the front of the engine, passenger side just below the head gasket. The oil just squirts out at the seal of the "fitting". Can you help me identify what component would be located in this area and is it easily replaceable? Thanks.
May 9, 2008 at 8:55 PM
Sounds like you're talking about the oil pressure switch-the fitting does it have a wire on it?
May 10, 2008 at 12:59 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Dose this fitting have one wire attached? if so it's the oil pressure switch, this will easily unscrew with a socket (remove wire first ) If not the pressure switch, there is also the oil filter located near that front of engine position you refer to, this will also "spin of"and is easily replaced. Check these items first... and if not these contact me via I.M.Mark (mhpautos)
May 10, 2008 at 1:00 AM
OWEN0118
Yes there is a wire going to it. Thanks!
May 10, 2008 at 9:36 AM
OWEN0118
I replaced the oil pressure sensor and it fixed the leak. Thanks for the quick response!
May 10, 2008 at 10:49 PM
KHLOW2008
  • 41,814 POSTS
Aug 15, 2008 at 11:53 AM
