1998 Toyota Camry can't stop shaking
1998 TOYOTA CAMRY
100,000 MILES • 6 CYL • FWD • AUTOMATIC
KEYSERSOZE
I have a 98 Toyota Camry V6 that has a vibration at highway speeds. I had the front end aligned because the front tires were worn on the inside edge (not rotated properly), and was told that it was already within specs. I bought 4 new tires and it still vibrates after I took them back and had them rebalanced. I am thinking possibly the CV axles need to be replaced but I hate to throw money at that if that is not the problem. I do not hear any clicking while turning but have noticed that there is "play" in the drive train when going between coasting and accelerating while on the highway. I'm sure the struts could use replacing but I don't think that any are completely shot. I haven't noticed any play in the steering either. Also, I had a four wheel brake job recently and stopping is smooth. Any advise would be appreciated.
Dec 12, 2007 at 12:43 PM
You might be right with the CV Joints-also might want to have all the mounts engine/tranny inspected.
Could also be the ignition system is weak when you get up to cruising speed. Have the ignition system check with an oscilloscope
Dec 12, 2007 at 1:07 PM
