1998 Toyota Camry blue smoke at start
1998 TOYOTA CAMRY
825,000 MILES • 4 CYL • 2WD • AUTOMATIC
LIEUTCOU
My car recently failed inspection. Check engine light indicated a po401 code. egr vales were replaced. engine light came on 4 days later. I did notice that when I initially start my car i see a small puff of blue smoke. Could there be something else wrong that the check engine light came on again? do you have any idea how much it would cost for a valve job if this is required and is it dangerous to let it go for a while?
Apr 13, 2008 at 4:26 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Re check the code and see what has caused the re set. As for the smoke, you can leave it for a while as it is just a small amount o oil by passing the valve stem seals and valve guides. As for the repair cost, this is often unknown as you need to have the head off and fully inspected so you know the extent of the problem.
Mark (mhpautos)
Apr 13, 2008 at 6:02 PM
