1.Remove rear seat cushion and side seat back. Disconnect wheel speed sensor connector. Pull sensor wire harness out with grommet. Remove 2 clamp bolts holding sensor harness to vehicle body and strut assembly.
2.Remove wheel speed sensor. To install, reverse removal procedure. Tighten wheel speed sensor and brake components to specification.
Mar 5, 2021 at 11:24 AM
