window goes off track
1997 TOYOTA CAMRY
ALAN SUSCHANKE
how to adjust front pass window?
Jun 28, 2008 at 11:42 AM
MASTERTECHTIM
  • 4,750 POSTS
remove door panel and check the bolts holding on the window regulator for tightness, also look at the window regulator, its possible its bent and needs replacement. Here is an exploded view of the door which shows the window motor and regulator and how to adjust the window rails. Check out the images (below). Please let us know what happens.
Jun 28, 2008 at 11:45 AM
KHLOW2008
  • 41,814 POSTS
Hi alan suschanke,
Try spraying some silicone or wax lubricants on the door glass runchannel to see if it helps. Front area is most suspect, try using water to test.
Dead run channel will cause high friction resulting in the slanting glass when going up.
There are no adjustments available.
Jun 29, 2008 at 2:26 AM
JEEAM
i am retiree and i don't have income.my 1997 camry 6 cyl. LE driver side window trouble, some time works and some time stops at middle of operation. after 5-10 minutes moves little.it takes about 15 minutes to close complete window.
Feb 19, 2021 at 7:10 PM (Merged)
MHPAUTOS
  • 31,937 POSTS
Start with lubeing the window tracks. you can buy a specific spray on dry lube for this, if the motor is labouring, you may want to remove the trim and lube the winder mechanism, see how that works first,
JEEAM
Today I got time and try it the way described in answer but no out come.
is any other possibilities? pl. let me know so I can follow according.
Looking for your help.
Thanks
jeeam (girish)
SANTO2010
  • 6 POSTS
The driver's window gets off the fitting when I try to close the window. Please suggest the possible problem and cost to get it repaired.
SATURNTECH9
  • 30,869 POSTS
Do you mean it get's off track?Without removing the door panel to see what's going on it's hard to say how much it will cost without know what's wrong with it.
SANTO2010
  • 6 POSTS
You are right. It goes off the track.
[quote:ce91e9424e="saturntech9"]Do you mean it get's off track?Without removing the door panel to see what's going on it's hard to say how much it will cost without know what's wrong with it.[/quote:ce91e9424e]
SANTO2010
  • 6 POSTS
I just need a rough estimate.
Thanks
[quote:ae10c0ed89="santo2010"]You are right. It goes off the track.
[quote:ae10c0ed89="saturntech9"]Do you mean it get's off track?Without removing the door panel to see what's going on it's hard to say how much it will cost without know what's wrong with it.[/quote:ae10c0ed89][/quote:ae10c0ed89]
SATURNTECH9
  • 30,869 POSTS
Do you have manual or power windows?
Feb 19, 2021 at 7:11 PM (Merged)
SANTO2010
  • 6 POSTS
Its power windows.
Thanks
[quote:b8cff38c86="saturntech9"]Do you have manual or power windows?[/quote:b8cff38c86]
SATURNTECH9
  • 30,869 POSTS
Let's say worse case it's a broken window regulator that would be 1.3hr's labor time's shop labor rate 80-100 per hr?The regulator with motor is 45 plus shipping depending on where you buy it.
SANTO2010
  • 6 POSTS
Thanks a lot for helping with this deciding factor. I am buying this car having only this propblem, otherwise the car has 100K miles and runs great.
Thanks again
[quote:caf8557dd6="saturntech9"]Let's say worse case it's a broken window regulator that would be 1.3hr's labor time's shop labor rate 80-100 per hr?The regulator with motor is 45 plus shipping depending on where you buy it.[/quote:caf8557dd6]
SATURNTECH9
  • 30,869 POSTS
If your handy with tool's and want to save some money you could always pull the inner door panel off and fix it yourself.
SANTO2010
  • 6 POSTS
I would love to do that, but I am new with car, so will not take risk right now. :)
anyways thanks for boosting my confidence..
[quote:38087c658e="saturntech9"]If your handy with tool's and want to save some money you could always pull the inner door panel off and fix it yourself.[/quote:38087c658e]
MULDOON
  • 79 POSTS
Toyota camry 1993 the drivers side window goes off the track and does not close properly
KHLOW2008
  • 41,814 POSTS
Check the door runchannel. If they are bad, they can restrict the door glass movement causing it to go off track. Try some silicone based lubricant onto the runchannel where the door glass slides up. It might require repeated movement up and down to get the door glass moving smoothly again. DO NOT use oil based lubricants such as WD40, they would agrave the problem as oil would damage the runchannels causing the door glass to stick to the runchannels.
MULDOON
  • 79 POSTS
Thank you but that did not work still jumps off the channel about 5 inches from top and goes over and outside of the rubber gasket on left side of drivers window.
KHLOW2008
  • 41,814 POSTS
Remove the door panel and check the regulator to see if it is securely held. If yes, you would have to replace the runchannel.
FRANCESCA108
1993 Toyota Camry
I came back from vacation to find the back window on the driver's side won't roll up. The windows are manual. Is this a window regulator problem, and, if yes, approximately how much should it cost to repair this?
KHLOW2008
  • 41,814 POSTS
Hi francesca108,
If the handle turns without the glass moving, then it is the regulator gears that are worn off.
If it is stuck, it might be the glass getting stuck, try pulling it up by hand and winding with handle simultaneously.
Sorry, unable to provide costing.
