A friend's 97 Camry came to me with a possible disconnected shift linkage. Sure enough, the cable had popped off at the shifter and for good reason. The transmission lever (even disconnected from the cable) is frozen in place. It doesn't even wiggle as if a solenoid lockout but rather won't even budge. As best I can tell it would be in the drive position. What could be the cause of this? Fluid level fine and not burnt. No leaks. Have you ever seen this before?
Aug 21, 2009 at 11:39 PM
