1997 Toyota Camry oil pump
1997 TOYOTA CAMRY
175,000 MILES • 4 CYL • FWD • AUTOMATIC
DHENNE518
How to replace the oil pump?
May 5, 2008 at 6:09 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Remove the sump & the oil pick up pipe. Remove the front timing belt cover & timing belt, remove crank shaft primary gear, unbolt the oil pump housing and carefully remove pump & housing.
Mark (mhpautos)
May 6, 2008 at 1:36 AM
