My car was running fine except for a little skip when sitting idling. The code read misfire on #4 cylinder so I had the spark plugs and wires changed. After changing them the car does not have any power, like it bogs down when you press the gas. Had new coil packs put on and made no difference. Checked EGR and pulled fuse on EFI to let it reset and still no change. The code now reads misfire on 3, 4, and 5 cylinder. The grounds were checked also. Also check the timing marks and the timing belt and they are good. Any suggestions?
Aug 14, 2009 at 9:17 AM
