I just put in a new radiator, thermostat & coolant temp switch. I also tested the main eng. relay, & cooling fan relay no. 1, they tested ok.I also checked for any blown fuses relating to this issue, all fuses are fine.I cant even get the A/C fan to turn on, when a/c is in use.I also ran power to both fans directly from the battery, they both turned fine. Any suggestions would be appreciated.Justo
Apr 26, 2008 at 7:57 PM
