1997 Toyota Camry 97 Camry Misfires and has fuel smell
1997 TOYOTA CAMRY
140,000 MILES • 4 CYL • 2WD • AUTOMATIC
JOHNTW12
Camry started running rough at idle and while driving. Check engine indicator sometimes flashes and sometimes not. Notice fuel smell. Plugs and wires are about a year old and look fine. Checked emissions hoses - all seems to be ok there.
Can you help or give some pointers?
thanks!
John
Nov 7, 2009 at 7:10 PM
STEVEW84
  • 673 POSTS
sounds like you have a misfire. what is the code?
Nov 7, 2009 at 7:47 PM
JOHNTW12
Steve,
There are 4 codes:
P0300 - random/multiple misfire
P0302 - cyl 2 misfire
P0303 - cyl 3 misfire
Can it be upstream from the injectors? I'm pretty sure the fuel filter and charcoal canister haven't been replaced.
Thanks,
John.
Nov 8, 2009 at 5:30 PM
STEVEW84
  • 673 POSTS
Could be bad inj. Could also be bad ignition parts. I would clear the codes and see what comes back.
Nov 9, 2009 at 7:25 AM
