Engine Performance problem
1996 Toyota Camry 6 cyl Front Wheel Drive Automatic
Toyota Camry 1996 (sept) 1MZ-FE engine.
I'm in Mexico, bought a well repaired Calif. write off, probably has 200,000 Km. two years ago.
6 months now, smokes on startup(blue, oil?) once every 30 times, when cold, it failed emissions test (hydrocarbons, only barely above the limit).
Seems to me, running rich. Lots of black soot on the exhaust pipe, hesitates, backfires when taking off from a start.
NO check engine light, NO error codes. Has me wondering how is this possible? Bad cat converter, something after the O2 sensor?
New oil & filter, plugs 3000 miles old, air filter year old.
How can this be so bad, without check engine light?
Jul 21, 2010 at 11:43 PM
