1996 Toyota Camry Running hot
1996 TOYOTA CAMRY
LYNETTNE
1996 Toyota Camry 4 cyl Wheel Drive Type unknown Manual 119000 miles
Car is leaking antifreze and is running hot.
Feb 8, 2008 at 6:34 PM
BLACKOP555
  • 10,386 POSTS
Can you see where the antifreeze is leaking?
Feb 8, 2008 at 7:57 PM
LYNETTNE
I think it's leaking from the distributor cap.
Feb 8, 2008 at 8:16 PM
BLACKOP555
  • 10,386 POSTS
That is very highly unlikely VERY VERY VERY UNLIKELY.
if by some means it came out of there the vehicle wouldnt be running to get hot
Feb 8, 2008 at 8:45 PM
LYNETTNE
I was told by a friend of mine that the leak was coming from the cap. That didn't seem right. I know that I seen it coming under the car, not sure where.
What do you think it can be.
1. a hose.
2. the radiator.
3. a thermostat problem.
Feb 8, 2008 at 9:00 PM
BLACKOP555
  • 10,386 POSTS
can come from many things.
bad radiator, bad freeze plugs, cracked block, warped/crackedhead, bad headgasket, bad radiator hose. many things can you get a picture?
Feb 8, 2008 at 9:26 PM
