1996 Toyota Camry RPM Changes when Stopped
1996 TOYOTA CAMRY
113,000 MILES • 4 CYL • FWD • AUTOMATIC
MICHELLEUCH
When the car is in Drive and I come to a stop, the RPMS decrease to below 1 and as I sit for a second it jumps up then goes back down and keeps jumping up and down every few seconds.
Nov 20, 2008 at 10:35 AM
KHLOW2008
  • 41,814 POSTS
Hi michelleuch,
Thank you for the donation.
Engine surging is due to a fault in the idling system, usually idle speed out of specs, (too high) and possible causes are,
1. Faulty Intake Air Conttrol valve.
2. Vacumn leakages.
3. Faulty MAP sensor.
4. Insufficient engine coolant.
5. Idle speed adjusted too high (could be A/C Fast Idle Control adjustment)
Usually a cleaning up of the throttle body and readjustment of the idle speed (if equipped with idle adjust screw) would solve the problem.
Nov 20, 2008 at 11:53 AM
