1996 Toyota Camry replace starter
1996 TOYOTA CAMRY
155,000 MILES • 4 CYL • FWD • AUTOMATIC
RHCOX
How to replace starter
Jan 28, 2009 at 8:25 PM
STARTER MOTOR
Removal & Installation
Disconnect negative battery cable and then positive cable. Remove battery and tray. If equipped with cruise control, remove cruise control actuator cover, cruise control actuator, and actuator bracket from body mount.
Remove starter terminal/wire cover and remove starter wires. Remove starter. To install, reverse removal procedure. Tighten starter mounting bolts to 29 ft. lbs. (39 N.m).
Apr 25, 2020 at 1:04 PM
