Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Camry
Engine
Symptoms
Compression
1996 Toyota Camry Low compression
1996 TOYOTA CAMRY
100,000 MILES • 4 CYL • 2WD • AUTOMATIC
DADHANNEY
MEMBER
1 POST
FOLLOW
Does low compression in each cylinder mean timing belt problem?
Oct 6, 2009 at 2:54 PM
DOCFIXIT
CERTIFIED EXPERT
That's a possibllity does engine run? What are comp. readings? Think there is an view port in T cover put crank at TDC then see cam mark. see diagram
Oct 6, 2009 at 3:14 PM
