The door locks and the power windows were not working. The cause was the wires at the door hinge were short circuited. I taped them and changed 30A fuse located behind the fuse junction box. The locks and the windows worked fine for two days, after which the windows are ok but the locks are behaving weird. When I open the lock with the key only the driver side lock opens. i insert the key in the ignition switch and turn it to Aux mode, all the locks are opened. when I try to lock the doors from the main switch on the driver side or from the individual switches there is a clicking noise but the locks are not locked. It seems that they want to lock but some thing is preventing them to do so. pls help
May 5, 2008 at 5:59 PM
