1995 Toyota Camry Vibrating wheel and transmission fluid co
1995 TOYOTA CAMRY
MELLOW249
1995 Toyota Camry 4 cyl Front Wheel Drive 99,432 miles
My Toyota Camry's steering wheel vibrates when I accelerate to and above 35 mph. I also notice that the car is very slow/resistant to increasing speed and a strong burnt rubber smell is evident. I recently had the transmission fluid changed due to the black color of the fluid. The mechanic told me this was due to the fluid burning and not being replaced when it should have been. He flushed out the old fluid, replaced it and said that this procedure may cause problems to the transmission which may need to be replced with a rebuilt one. I was told that the cost would be around $1,500 and if I took it to the Toyota Dealer it could cost as much as $4,000 (for a new one I assume!). The mechanic test drove my car but did not notice any problems. Please help me.
Apr 24, 2010 at 4:40 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
i would get a transmission specialist to do a test and report on this transmission, it may well be due for overhaul as the burnt oil would have been caused by the transmission slipping.
Mark (mhpautos)
Apr 26, 2010 at 8:44 AM
MELLOW249
Just wondering if you think this could be caused by a problem with the CV Joints ?
Apr 26, 2010 at 7:22 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
When CV's start to fail they knock on hard turns, i do not believe that this is your problem.
Mark (mhpautos)
Apr 27, 2010 at 2:41 AM
