1995 Toyota Camry TRANSMISSION STOPS WORKING AFTER ENGINE W
1995 TOYOTA CAMRY
210,000 MILES • 6 CYL • 2WD • AUTOMATIC
JJBW
i AM ABLE TO START THE VEHICLE AND DRIVE OFF.
AFTER ABOUT A FEW MINUTES AFTER THE ENGINE WARMS UP THE TRANSMISSION STOPS WORKING AND THE VEHICLE ROLLS TO A STOPS. THE ENGINE IS STILL RUNNING FINE AFTER THE VEHICLE COMES TO A DEAD STOP.
i HAVE NOT HAD A TRANSMISSION TUNE UP ON THIS VEHICLE FOR A LONG TIME. THE TRANSMISSION FLUID IS STILL RED COLOR.
Jul 31, 2010 at 1:42 AM
MHPAUTOS
  • 31,937 POSTS
Hi there,
You will have to get the transmission line pressure check, this can be done by a trans tech as they will have the correct equipment to do this, you can get a scan done as well to check for any unresolved transmission fault codes, start here.
mark (mhpautos)
Jul 31, 2010 at 2:29 AM
