HI there,
You must remove the front pulley, engine mount timing cover & timing belt to access the water pump, the timing belt alignment is extremely critical and must be correct or engine damage will ensure, often this ob is beyond the home mechanic so i would suggest that you get a manual and have a good read up and if in doubt about doing this job, get your mechanic to do it.
Mark (mhpautos)
Aug 25, 2008 at 6:11 AM
