1995 Toyota Camry rear window
1995 TOYOTA CAMRY
MOSLEY070188
1995 Toyota Camry
how do you install the rear driver side window to a 95 toyota camry. it isnt the rear window that rolls down though it is the small piece of glass behind the one that rolls down. please help
Jun 2, 2009 at 5:50 PM
KHLOW2008
  • 41,814 POSTS
Hi mosley070188,
You are refering to the quarter glass.
To install the quarter glass, you would need to remove
1. Door panel.
2. Door glass. detach it from the window regulator and you can get it away from obstructing.
3. Runchannel guide, the piece holding the glass that you are going to install. Remove holding bolt at bottom and screw on top, hidden by the weatherstrip.
Glass should be installed onto weatherstrip before installation.
Jun 6, 2009 at 11:29 AM
