Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Camry
Steering
Pump
Replace/Remove
1995 Toyota Camry Power Steering Pump removal
1995 TOYOTA CAMRY
130,000 MILES • 4 CYL • FWD • AUTOMATIC
ROADS.ZX
MEMBER
FOLLOW
What do I need to remove in order to access and remove the power steering pump?
May 1, 2010 at 3:00 PM
KHLOW2008
CERTIFIED EXPERT
Hi Roads.zx,
Apart from the belting you need to disconnect the pressure and delivery hose, vacumn hoses and the holding bolts.
Space is rather tight and you might need to get under the vehicl for easier access.
May 1, 2010 at 3:27 PM
