1995 Toyota Camry engine warm and cold idle problem
1995 TOYOTA CAMRY
90 MILES • 4 CYL • 2WD • AUTOMATIC
ANTWAN
I just had an engine swap into the camry and it ran great. The only two things are the cold idle rpm seems low and rough and when the engine is warm the idle is high at 1000 rpm. Is it the idle valve controller? Does it need to be replace or I can used from my old engine which worked just fine. thanks you
Feb 25, 2009 at 1:19 PM
Test the coolant tempearture sensor and cold start injector-clean out the idle air control valve then report back
Feb 25, 2009 at 2:30 PM
