1995 Toyota Camry Black smoke comes out of the tailpipe
1995 TOYOTA CAMRY
115,000 MILES • 4 CYL • FWD • AUTOMATIC
O2 SENSOR
Hi! my 95 toyota camry has Black smoke comes out of the tailpipe when I push the gas.[img:d7be11a421]http://www.2carpros.com/forum/automotive_pictures/573699_aaa_1.jpg[/img:d7be11a421] and the idle is below 1 and the engine keeps making sound like Bak Bak Bak at the tailpipe and also the oil turns black after a week or less, and i did a compression test and all cylinder were like 185 PSi and one of the spark plugs has oil on it and all them were black and burnt and the red Arrow on the picture there like three hoses when i pulled them out the idle goes back to 1 rpm and when i put them back the idle gets missed up and drops to near 0 and i belive one of those hoses come from a thing like a sensor or some electronic unit and the one other hose comes from the Brake booster. So Please Any help would really be appreciat it
Sep 16, 2010 at 8:16 PM
Sounds like its running too rich-check the injector/s and the fuel pressure regulator if its leaking
Sep 17, 2010 at 3:28 AM
O2 SENSOR
[quote:aa3caf7857="rasmataz"]Sounds like its running too rich-check the injector/s and the fuel pressure regulator if its leaking[/quote:aa3caf7857]
Hi, So don't you think i have some block damage or pistons ? and how can i fix the running rich fuel ? i tested the injectors with stethoscope and they clicks when the car idles .
Thanks
Sep 17, 2010 at 5:35 AM
Pull the vacuum hose from the fuel pressuer regualtor and check if it has gas-also could be the oxygen sensor or the coolant temperature sensor stuck in the open loop mode giving fuel when not needed-
If it continues it will ruin the engine cylinders/washed out-check your oil if it has gas
Sep 17, 2010 at 5:40 AM
O2 SENSOR
[quote:c773150e71="rasmataz"]Pull the vacuum hose from the fuel pressuer regualtor and check if it has gas-also could be the oxygen sensor or the coolant temperature sensor stuck in the open loop mode giving fuel when not needed-
If it continues it will ruin the engine cylinders/washed out-check your oil if it has gas[/quote:c773150e71]
no gas in the vaccuum line.
I see that there was no coolant and when I add some and after a while its gone and its not leaking and i dont think its the head gasket either but the oil is really black and smells like gas . How do i test the O2 sensor if it works ?
Thank you so much
Sep 17, 2010 at 6:54 PM
Double check the injectors if its leaking and also if the fuel return line is clogged causing excessive fuel pressure.
Testing the oxygen sensor:https://www.2carpros.com/articles/how-to-test-an-oxygen-sensor-02-sensor
Sep 18, 2010 at 2:13 AM
