1995 Toyota Camry almost full rich fuel feed
1995 TOYOTA CAMRY
126,000 MILES • 4 CYL • 2WD • AUTOMATIC
DON COLEC
I PERFORMED A VALVE JOB AFTER AN OVERHEAT CAUSED A HEAD GASKET LEAK. EVERYTHING WENT WELL, CAMS LINEUP, ALL IS WELL EXCEPT RICH FUEL SUPPLY ON START AND AFTER WARMED-UP. SO RICH IT WILL BARLY IDLE AND OF COURS FOULS PLUGS. WILL RUN AT HIGH SPEED BUT NOT LOWER SPEEDS. ALL GROUNDS ARE GOOD, THE READOUT IS 52 KNOCK SENSOR. HOWEVER 4 CYLS. DON'T HAVE KNOCK SENSOR. NO OTHER CODES PRESENT EXCEPT OBVIOUS OVER FUELING RELATED EMISSION WARNINGS. OBD-1 SYSTEM. SPARK IS STRONG, COMPRESSION IS GOOD, FUEL IS FRESH TPS IS WITHIN LIMITS,O2 SENSORS OK JUST DIRTY FROM EXCESS FUEL. CAN'T FIGURE IT OUT.
May 11, 2008 at 9:36 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation.
Check that the cold start injector is not leaking. do a fuel rail pressure test to show any main injector leaks. Make sure that the ignition timing is set with the ECU in check mode & the valve timing is set correctly. start here,
Mark (mhpautos)
May 12, 2008 at 12:19 AM
