1994 Toyota Camry Overheating
1994 TOYOTA CAMRY
TYSMITH
Other Category problem
1994 Toyota Camry 4 cyl Front Wheel Drive Automatic 104.00 miles
I have a 94 Toyota Camery. The radiator had a crack in the top so I replaced it. The car still overheated. So I replaced the thermistat because the bottom hose on the radiator was not getting hot. The car is still overheating. The top hose does build up pressure and when I took off the old thermistat, a lot of coolant came out from behind the thermistat. I thought it was the thermistat because of the bottom hose being cold and the heat not working but now I'm thinking I am wrong. Please help
Jan 2, 2008 at 12:12 PM
Replace the thermostat and bleed the cooling system out. If it continues have it block and pressure tested for combustion gases entering the system.
Jan 2, 2008 at 12:28 PM
