I HAVE NO PRESSURE ON CLUTCH PEDAL WHEN I PUSH IT IN TO CHANGE GEARS ALSO STUCK IN FIRST GEAR
Jun 18, 2010 at 2:33 PM
DOCFIXIT
CERTIFIED EXPERT
Check fluid in clutch master cylinder. Either master or slave cylinder on trans has failed.
Jun 18, 2010 at 3:16 PM
FORDRACING24
MEMBER
You could also have broken the fork which releases the clutch from the transmission which would cause the car to start but be stuck in first. Happened to a friend of mine
