1994 Toyota Camry no fuel,no fire
1994 TOYOTA CAMRY
180,000 MILES • 4 CYL • FWD • AUTOMATIC
KJACK167
i have recently put a timing belt on , ran great for 3 weeks ,now, no fuel pressure(not pumt all)no fire... i have already replaced the distibutor and still nothing. the guy at advanced said it had an inercha(reset) switch. is this true and if so where is it located? if there is not a switch does this car have a crank sensor.
Mar 7, 2010 at 5:08 PM
KHLOW2008
  • 41,814 POSTS
Hi kjack167,
Thank you for the donation.
The crank sensor is located in the distributor.
Does the MIL come on when the ignition switch is turned on and while cranking?
Did you check the EFI main relay?
Mar 8, 2010 at 11:28 AM
2 LINSEY
  • 287 POSTS
Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
Mar 18, 2010 at 12:47 PM
