1994 Toyota Camry ignition module
1994 TOYOTA CAMRY
158,000 MILES • 4 CYL • FWD • AUTOMATIC
J BOWEN
the car started and ran perfectly until two days after it was detailed. It began to start rough and the next day it wouldn't start at all. I've replaced the battery, cap, and roter. However, there is no spark generated. Would this be the coil or ignition module and where is the ignition module located?
Jan 12, 2010 at 11:55 PM
Could be either one -check and test the primary and secondary resistances of the coil, now the module needs a special testing Eq. also test the distributor pick-up coil-inspect wiring
Jan 13, 2010 at 1:34 AM
