1994 Toyota Camry Electrical - Fuse holder
1994 TOYOTA CAMRY
213,281 MILES • 6 CYL • 2WD • AUTOMATIC
KIEM LOON
Hi dear sir,
I have a Camry 1994 and I'm having almost a fuse holder going to get burned :/. I have been looking throe the internet to get the parts that i needed but, im not a technician and dont know the specific name of the Fuse holder at the Instrumental panel on the driver side . You could see at the pic.
If you can help me how the item is called and where i can order one to able shipped world wide, i thought it was called Intrumental fuse holder, but all i got from the internet are diagrams :/
Another question what kind of fluid you used to clean your engine oil after you empty it???and after that you just replace the engine oil filter and then put 4/5 motoroil.
Yours faithfully
Jul 11, 2010 at 8:29 PM
KHLOW2008
  • 41,814 POSTS
Hi Kiem Loon,
Thank you for the donation.
An you upload a picture so we can identify what it is that you are referring to?
When engine oil is drained off, you cannot use anything to flush it as it would not help. There are many brands of engine flush available and it is put into the engine just before an oil change. You run the engine for a specific time to flush it and then drain off and rerplace with new oil.
I would not recommend any engine flush as most of them do not work and it is going to hurt the engine more than help.
Jul 12, 2010 at 2:53 PM
