Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Toyota
Camry
Trouble Codes
OBD1 Codes
Code 13
1994 Toyota Camry code 13
1994 TOYOTA CAMRY
78,000 MILES • 4 CYL • FWD • AUTOMATIC
42HOTROD12
MEMBER
FOLLOW
has code 13 replaced distributor checked wiring and connectors to ecm
is a bad ecm common on this car?
Oct 9, 2009 at 4:10 PM
CERTIFIED EXPERT
DTC 13 G, NE Signal Circuit No. 2.
Distributor has been replaced wiring has no open or short circuit-last place is the ECM either you swap or replace it-and see what happens
Oct 9, 2009 at 5:17 PM
