My brake light functions but is dim?
1994 TOYOTA CAMRY
198,000 MILES • 4 CYL • FWD • AUTOMATIC
GMERCER
My brake light functions but is dim when the tail lights are off(daytime) but does not work when taillights are on.With lights turned on the taillight goes out completely when the brake pedal is depressed. I replaced the bulb but this made no difference.
Nov 21, 2008 at 7:27 AM
The most common cause of a dim bulb is high resistance in the circuit that is causing the bulb to not illuminate completely.
Here is a guide that will help with this:
https://www.2carpros.com/articles/one-headlight-is-dim-or-dull
However, within this issue itself the leading cause of it is corrosion on the socket. So more than likely we need to replace the socket in order to restore the brightness.
Here is an excellent video by Ryan that shows how to do this. He takes you through how to solder in a new socket so that it is done properly.
https://www.youtube.com/watch?v=PxA5wczsCVo
Please run through this info and let us know what questions you have.
Nov 12, 2021 at 10:41 AM
