1994 Camry Japan, I4, 5SFE, automatic, 165,000 diagnostic code 12, No RPM signal. Car seems to run fine except every now and then the car will misfire and check engine light will go ON. Car will then apparently correct itself because the check engine light will go OFF. Idles fine except once in a while it will misfire,.. not predictable. It only stalled on me once but started right up,.. hopefully not a sign of future problems. Entire distributor assembly completely replaced 4 years ago, replaced fuel pump & filter 4 years ago. New wires, plugs, rotor last month. Still has original ignitor and ALL original senors. Not sure when to replace sensors. Do you wait to get a fault code for a particular sensor then replace? Has been a great car. My fault code 12 is my problem right now. Any thoughts? Thanks
Aug 2, 2007 at 7:01 PM
