The brake pedal on my Camry wagon continues to go to the floor with no loss of fluid. Brakes were great until today, when I replaced a short section of line due to rust. This was a rear brake line which runs between a coupler under the rear seat drivers side, and the LPSV (load pressure sensing valve). I replaced one of the two lines, and have bled all four corners AT LEAST A DOZEN TIMES at the bleeders. There are absolutely no fluid leaks. I suspected my master cylinder might have blown seals in the process, so I replaced with a brand new master cylinder. Problem did not change at all. Pedal has spongy pressure but drops to the floor. Car won't stop and is not driveable. Do I have to somehow bleed the LPSV? Is there a unique bleeding procedure with this car? If there is still air in the system somehow, wouldn't I at least have spongy, working brakes? HELP PLEASE!! THANK YOU!!!!!
Oct 12, 2008 at 5:50 PM
