1993 Toyota Camry Radiator Fans not blowing
1993 TOYOTA CAMRY
171,000 MILES • 4 CYL • 2WD • MANUAL
GERR UT
Recently I have been having problems w/ my Camry overheating. I flushed the radiator and added a 50/50 anitfreeze/ antiboil. I think the thermostat is sticking and needs to be replaced b/c cold air comes out when I have the heat on. Although I also noticed that the fans aren't blowing on the radiator when he the temperature gauge goes up. I have a Haynes repair manual for my car, but I can't find specifics regarding the radiator fans. Any pointers on what I might check would be greatly appreciated. Thank you.
Roger
Nov 25, 2009 at 4:39 PM
Replace the thermostat, as for the fans-check and test the fan relay, coolant temperature sensor and engine temperature gauge switch
Nov 25, 2009 at 6:25 PM
