1993 Toyota Camry fuel pump problems
1993 TOYOTA CAMRY
175,000 MILES • 4 CYL • FWD • AUTOMATIC
DAVIDDLW1
  • 23 POSTS
my car would not start so the first thing i done was to check the fuel pump. i tried listning to see if i could hear the fuel pump under my back seat and through the gas filler cap but when i turn key to on on car i could not hear the fuel pump engaging. i took fuel pump out of car and tested it and the pump was bad. i purchased a nother fuel pump and tested it before i installed it and it operated great. but when i tried to start the car it would not start. i done what i did befor by listning for the pump to engage when key turn to on but did not hear pump engage. i took pump out again and tested it the pump worked great. i tried testing the pump out of the gas tank by having it hook up and turning car to on and the pump would not engage. so i guess the problem has to be in the fuse or relays so i tested the fuses and all fuses tested good, my car book said to check the efi main relay and the circuit open relay. i put in another efi relay but i did not see the circuit open relay. the book showed it on the fire wall in the middle next to the vacum sensor. the vacum sensor i saw but there was no circuit open relay on the firewall. can you tell me where this relay is or is it my relays?
Apr 12, 2010 at 7:55 PM
Hi daviddlw1, Welcome to 2carpros and TY for the donation
In the check connector jumper Fp to Batt turn key on the fuel pump should come on-let me know so we can continue.
Also do this when above is done: At the airflow meter block the flap wide open and attempt to start-
Note: The airflow meter has to ground the circuit opening relay in order to power up the fuel pump.
Feb 9, 2019 at 7:20 PM
DAVIDDLW1
  • 23 POSTS
the advise you gave for my fuel pump worked great. now my fuel pump is operating correctly and my car starts right up..thanks
2 LINSEY
  • 287 POSTS
Hi daviddlw1, good to hear you got your camry working. Thank you for using 2CarPros.com. We appreciate your donation and look forward to helping you in the future.
