1993 Toyota Camry dash lights.
1993 TOYOTA CAMRY
15,000 MILES • 4 CYL • FWD • AUTOMATIC
FHUMBLE
Whenever my car is in "drive" the D on the dash does not lite up and when I press on the brake the R lites up. The light warning icon (little car) on the dash lites up the first time I step on the brake and stays on continuosly untill I turn the car loff again.
Sep 1, 2010 at 4:00 PM
KHLOW2008
  • 41,814 POSTS
Hi fhumble,
Thank you for the donation.
The D light not indicating could be due to a blown bulb or a fault with the Park Neutral Position switch. You would ahve to remove the meter cluster to test or replace the bulb.
When the R indicator light comes on while braking, it is usually caused by a abd ground circuit at the rear taillights. Check the taillight gound circuits. Remove, clean, retighten and retest.
Sep 2, 2010 at 9:30 AM
