1993 Toyota Camry 1993 toy camry no power to ac clutch
1993 TOYOTA CAMRY
130,000 MILES • 4 CYL • 2WD • MANUAL
DAVIDOCON
MEMBER
FOLLOW
no voltage to ac clutch,checked relays,fuses,wireing,no problems found.
Jun 21, 2008 at 11:30 PM
KHLOW2008
CERTIFIED EXPERT
Hi davidocon,
Is there power supply to AC clutch relay?
Is the relay clicking when the AC is turned on?
Aug 29, 2020 at 12:18 PM
DAVIDOCON
MEMBER
yes there is power to ac cluch relay,I also replaced the relay.checked relay for power and good ground,no problem found,I checked the ac control switch on the control panel ,ok,replaced the swich because I did not hear the relay clicking.still no powert to ac clutch.
KHLOW2008
CERTIFIED EXPERT
Hi davidocon,
The AC clutch is a special type relay, did you replace with correct type?
There are 4 points but only 3 are used. Check the Blue/White wire from realy to see if it is grounded when AC is turned on.
Does applying ground to this wire operate the clutch?
