Hi and thanks for your reply.
Yes I think they are made in China ( which is for sure) or they are remanufactured. So i think i have to take it back and get them to change them.
I also have started having 2 other problems with it.
1) is that recently when i leave the car in the cold,, like in an open parking lot for a long time like for an 8 hours work, when i start the car and try to drive away right away, the steering wheel gets tight,, or it doesn't turn to one side,, so when you try to trun the wheel,, it doesnt turn the wheel,, as if it is stuck,, but after a while,(like when the car is warm and ready to go) the problem is resolved and there is no problem driving.
2) the gas/milage ratio has increased dramatically, so it actually takes 18 litres/ 100 Km. (I do metric since i am canadian) :) i think it is 4.5 gal/60 miles.
What could that be? I have new wires and sparks plugs that i changed myself recently.
Thanks a lot for your reply.
Ben
[quote:eefe9a9f16="fisherman"][quote:eefe9a9f16="Benny84"]Hi ,
I have a 1993 Camry, 140K miles, 4 cylinder, 2200cc,
Recently I had problems when i accelerated like when getting from the ramp to the freeway, and the car started shaking until reaching a steady speed. So a mechanic changed the drive shafts of both sides and the problem is fixed now. but i have encountered that since then the car feels as if it is heavy so it doesnt accelerate as fast as before. Any reasons why this is??
I appreciate your help.
Thanks[/quote:eefe9a9f16]
hello !!
Did you installed brand new shafts or remanufactured?
sometimes the ball joints are too tight that the "balls" on the racers get "stuck" and its really hard to transfer the power to the wheels (once on angle)..
looks hard to believe but that happens to me one time i bought a pair of "brand new" made in China drive shafts, I installed them and I can`t even turn the wheel to tight the allen screws!! I took them out and found that the steel balls wont "fit" on the racers! I had to use a moto-tool to "grind" the racers and make it fit.. after that problem fix!
after that I don`t trust those "China" replacement parts!!
find that and let us know!![/quote:eefe9a9f16]
Nov 29, 2007 at 8:22 AM
