1992 Toyota Camry vibration
1992 TOYOTA CAMRY
334,000 MILES • 4 CYL • AWD • AUTOMATIC
SCVCKC123
  • 7 POSTS
I have a 1992 Toyota Camry LE 4 cylinder. When braking especially coming down a hill or incline there is a very bad vibration the whole front end shakes. New brakes and rotors and a new axel on the drivers side were replaced in August. What could be the cause of this when braking?
Thank you so much!
Nov 24, 2009 at 7:59 AM
KHLOW2008
  • 41,814 POSTS
Hi scvckc123,
Thank you for the donation.
Vibrations during braking are usually caused by rotors running out of lateral. Though they have been replaced, we cannot rule out the possibilities.
At what driving speed does it occur?
Other possible causes are :
1. Worn steering linkages.
2. Bent wheel rims.
3. Uneven tires.
4. Worn ball joints.
Nov 24, 2009 at 8:12 AM
SCVCKC123
  • 7 POSTS
Hi
Thank you for your quick response can you please explain to me what "rotors running out of lateral" means?
The speed does not seem to matter it happens going fast or slow when braking. When braking on a flat surface it is minimal but when coming down a hill it is bad.
I really appreciate your help
Nov 24, 2009 at 8:23 AM
KHLOW2008
  • 41,814 POSTS
Running out of lateral means the rotors have runout making them wvy when moving and when brakes are applied, the motion is transmitted to the vehicle and most noticeable the steering.
If the problem is occurring at low speeds, the rotors are less likely to be the cause.
The wheel and tires are quite likely to cause this problem.
Check the tire lug nuts torquing, looseness can cause the problem as well.
Check the wheel bearings and CV shaft central nut torquing .
Nov 24, 2009 at 8:44 AM
SCVCKC123
  • 7 POSTS
Ok thank you the tires have been rotated and the lug nuts have already been checked and tightened.
I guess the next things to check are the “wheel bearings and CV shaft central nut torquing”
Nov 24, 2009 at 8:52 AM
KHLOW2008
  • 41,814 POSTS
You are welomed and thsnk you for using 2carpros.
While you are at it, remember to check the ball joints and steering linkages.
Nov 24, 2009 at 9:14 AM
