1992 Toyota Camry shrader valve
1992 TOYOTA CAMRY
214,000 MILES • 4 CYL • 2WD • AUTOMATIC
MACMAMMA
How do i find the shraeder valve for fuel pressure relief?
Oct 13, 2010 at 1:49 PM
You don't have one-see below FUEL PRESSURE RELEASE
https://www.2carpros.com/forum/automotive_pictures/12900_test_port_2.gif
Disconnect the cable from the negative (-) terminal of the battery. CAUTION: With Airbag, work must be started after approx. 30 seconds or longer from the time the ignition switch is turned to the LOCK position and the negative (-) terminal cable is disconnected from the battery. Put a suitable container or shop towel under the fuel filter. Slowly loosen the union bolt at the fuel filter outlet. When complete, retighten the union bolt. Torque: 29 N.m (300 kgf.cm, 22 ft.lbs) Reconnect the negative battery terminal.
Oct 13, 2010 at 2:24 PM
