You don't have one-see below
FUEL PRESSURE RELEASE
Disconnect the cable from the negative (-) terminal of the battery.
CAUTION:
With Airbag, work must be started after approx. 30 seconds or longer from the time the ignition switch is turned to the LOCK position and the negative (-) terminal cable is disconnected from the battery.
Put a suitable container or shop towel under the fuel filter.
Slowly loosen the union bolt at the fuel filter outlet.
When complete, retighten the union bolt.
Torque: 29 N.m (300 kgf.cm, 22 ft.lbs)
Reconnect the negative battery terminal.
Oct 13, 2010 at 2:24 PM
